GDL left behind – no Surface Texture in section
runxel
After intensive testing I came to the conclusion that surfaces with textures defined in GDL directly are not shown in sections/elevations where you've set them to show Surface Textures. (showing textures from normal materials work fine, tho)
This somehow matches the experience of James.
It is worrysome that GS has not learned from the mistakes of the past (BMATs anyone?)...
Will this functionality be delivered, GS? @Peter Baksa ? (:
Mostly AC 26 on Mac | Author of SelfGDL | Developer of the GDL plugin for Sublime Text |
Sunny75
Yeah I experienced the same issue, very frustrating. Working in the field of interior design, we really need this functionality!
BrunoH
Won't it make any difference if you create your Surface Textures in a Master GDL Script rather than in the object script itself as a Master GDL Script can create project's Attributes ?
ArchiCad 3.43 to 26
MacOS Monterey
