GIANT Text editor
Tom Krowka
All of a sudden my text editor is filling up the whole screen, but only on text that is on a layout sheet. Can only see part of the text because the scale is so big. All I can do is hit escape.....and can only see part of the editor box. Never had this happen before...
Help please.
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
4 REPLIES 4
Katalin Takacs
Graphisoft Alumni
Graphisoft Alumni
Hi Tom,
Could you please attach a screenshot about the problem? Does it occur in one file only?
I look forward to your reply.
Regards,
Katalin Takacs
Tom Krowka
It happened once before a couple of years ago. Recently it has happened only in one file. So I opened the editor, select all and copied, then deleted the text. Created some new text, pasted in the text, and has been fine ever since.
Don't know how it happened, but it was an easy fix.
Thanks
Tom
Thomas@wkarchwk.com
www.walshkrowka.com
alemanda
It happened to me yesterday. Very strange. I didn't do anything particular ... It never happened before.
AC 19 and AC21 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
Katalin Takacs
Graphisoft Alumni
Graphisoft Alumni
Hi All,
In case this issue occurs again or you can reproduce it, please forward the
- file
- steps to reproduce
- computer specification
to your local distributor, so we can check the files and find the reason of this phenomenon: http://www.graphisoft.com/purchase/
Thank you for your help in advance.
Katalin Takacs
