Graphic Overrides on Window Trim
I cannot seem to get window trim to change surface with a GO. I can only do the entire window, glass included. Has anyone tried this, and/or got it to work?
4 REPLIES 4
DGSketcher
Legend
GO was not created as a materials override tool, it was originally developed for the purposes of highlighting structures with particular property values e.g. fire rated walls could be highlighted in a particular colour. So to answer your Q, it will not work as a means of changing sub materials in windows.
Guru
The same goes for wall, roof and slab materials. Any override will override the object in its entirety.
Win10 | R5 2600 | 16GB | GTX1660
reidweber
Hello, has there been any development with the GO tool to work with sub surfaces on things like window trims?
ArchiCAD 24, 25 & 26 US
WINDOWS PC, 16GB RAM, Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz 3.40 GHZ, NVIDIA GEForce GTX 970, ASUS, CM6870, Rev X.0x
No, nothing new on that front. Would be nice though.
