Help! How do I unlink model in version 9 to create line draw
Hi I am new to the CAD work as my assistant used to do. I have recently switched to Archicad 9 (updated from 8.1). How do you unlink the model to convert it to a line drawing? That task has been changed and I cant seem to figure it out? I have a deadline and starting to feel the pressure. If anyone can assist me, I'd really appreciate it. Thank you
DesignEvo
4 REPLIES 4
Stress Co_
In the plan view, select the Section/Elevation marker.
Open section/Elevation Selection Settings.
Select "drawing" in the Status pull down menu.
Personally, I keep my elevations "live" and model everything. Very little 2D overlay (sections are another story).
Marc Corney, Architect
Red Canoe Architecture, P. A.
Mac OS 10.15.7 (Catalina)
Processor: 3.6 GHz 8-Core Intel Core i9
Memory: 48 GB 2667 MHz DDR4
Graphics: Radeon Pro 580X 8GB
ArchiCAD 25 (5010 USA Full)
From 3d windows save as .2dl! Then open the file and save it as .pln!
Good luck!
Stress Co_
Ah, I made the assumption you were talking about sections/elevations....
David Maudlin
DesignEvo:
Or from any view except the Plan view, copy (use the flat marquee if using the 3D Window) and then paste, the pasted elements will be only lines and fills.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
