Read more
Horizontal Boundary
Too Long
Where is the setting that allows the Horizontal Boundary to be adjustable in the Section View?
For some reason they've worked fine until now.
Thanks
AC26 AUS Full
11 REPLIES 11
@James B The icons in the view map match a Section View rather than an Interior Elevation.
YES! You did it, thank you very much.
It seems the designer locked this layer to reduce the number of selectable layers.
Thank you very much
AC26 AUS Full
