Horizontal section at a given height. How?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2007-06-28
05:27 PM
2023-05-30
12:29 PM
Rubia Torres
I would appreciate if somebody could tell me if there is any method of obtaining... _horizontal_ section views. Can an Archicad model be sliced horizontally, just like with the section/elevation tool, but horizontally?
3D cutting planes do it nicely, but I need it for 2D documentation.
I tried to insert an extra story at given height, but it turned out to be empty (unpopulated).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-06-28 05:36 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-06-28 05:56 PM
willa.ytong wrote:3D views are a really valuable aspect of documentation created with AC...so don't be afraid to use them, even if they are (unfortunately) unlinked once annotated.
With the 3D window view that you want - which I presume is a top-down axo view, internal engine, hidden line mode and appropriate cutting plane:
Select the marquee tool, then select the 'flat marquee' method (simple rectangle).
Marquee the view, issue Copy command/shortcut: you'll get a dialog asking if you want a scaled image, etc...
Open an independent Worksheet (AC11) or Detail (AC9 or 10) and Paste the content there. It should be to scale. Annotate as desired. Just have to make a note to yourself to remember to copy/paste again if the model changes since this is not 'live'.
Same process works nicely for axo views that correspond to building sections - to provide a useful small 3D 'key' drawing adjacent to sections in your document set that helps clients and builders really understand where the section cut is...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-06-28 07:15 PM
Karl wrote:Interesting concept. I'll have to give that a try!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-08-31 08:23 AM
yes,we need a horizontal cutting tool !
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-08-31 08:26 AM
hi sir !may I have your attention please,15 years now!we need a horizontal cutting tool similar to the vertical or section tool!
