Horizontal section at a given height. How?
Hello.
I would appreciate if somebody could tell me if there is any method of obtaining... _horizontal_ section views. Can an Archicad model be sliced horizontally, just like with the section/elevation tool, but horizontally?
3D cutting planes do it nicely, but I need it for 2D documentation.
I tried to insert an extra story at given height, but it turned out to be empty (unpopulated).
5 REPLIES 5
TomWaltz
There might be some creative workarounds to fake it, but there is no way out of the box.
Tom Waltz
3D views are a really valuable aspect of documentation created with AC...so don't be afraid to use them, even if they are (unfortunately) unlinked once annotated.
With the 3D window view that you want - which I presume is a top-down axo view, internal engine, hidden line mode and appropriate cutting plane:
Select the marquee tool, then select the 'flat marquee' method (simple rectangle).
Marquee the view, issue Copy command/shortcut: you'll get a dialog asking if you want a scaled image, etc...
Open an independent Worksheet (AC11) or Detail (AC9 or 10) and Paste the content there. It should be to scale. Annotate as desired. Just have to make a note to yourself to remember to copy/paste again if the model changes since this is not 'live'.
Same process works nicely for axo views that correspond to building sections - to provide a useful small 3D 'key' drawing adjacent to sections in your document set that helps clients and builders really understand where the section cut is...
AC 28 USA and earlier   ā€¢   macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Jere
Interesting concept. I'll have to give that a try!
ArchiCAD 26; Windows 11; Intel i7-10700KF; 64GB RAM, GeForce GTX 3060
Liqiang Lu
yes,we need a horizontal cutting tool !
hi sir !may I have your attention please,15 years now!we need a horizontal cutting tool similar to the vertical or section tool!
