How to hide/change Interior Elevation
i need to hide the interior elevation line . This lines are really necessary to fix the cuing edge (section) But when In plan it creates confusion.
I just need the central symbol in my plan thus my craftsman can identify the view point. but other lines is not necessary for them.
Lingwisyer
Guru
View => On-Screen View Options => Marker Range
5 REPLIES 5
David Maudlin
avishiplu:
There is an On Screen Display Option > Marker Range which shows or hides these lines. In any case, these lines do not print.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Hi David,
I didn't find that 'On Screen Display Option '. Can you please send me a screen shot?
Lingwisyer
Guru
David wrote:
avishiplu:
Thanks...... it's solved now.
