How to match properties only for Door / Window Marker?
Rajesh Patil
Any idea how to match the properties ONLY for the Door / Window Marker without matching any other properties from source object? Check the attached image for reference.
Rajesh Patil
AC 09-27 | INT | WIN11 64
Dell Inspiron 7591, Core i9, 9880H 2.30GHz, 16.0GB, NVidia GeForce GTX1650, 4.0GB, SSD Internal 500GB, Dell SSD External 250GB
6 REPLIES 6
Lee Hankins
Unfortunately this is not possible but I so wish it was.
Lee Hankins
ArchiCAD 4.5 - Archicad 29 Tech Preview
macOS Tahoe (26.0)
Miha_M
So do I.
As usual, a workaround solution is possible. Don't use the marker option, use an opening label.
| Archicad 4.5 - 29
martinij
Oh that would be nice to have!
But maybe @Miha_M has a point. Maybe it would be better to just have labels with the labelingtool and not different labels in every object and a labelingtool.
Martin Isak Jansen
(I'm the one everyone at my company asks the tech questions)
www.artec.no
Lee Hankins
Labels would work as they do with Zones. However, you can’t control the view of the door or window marker via model view options then. Instead you have to have multiple additional layers for every different variant of door label which in my opinion is a backwards step especially in relation to Zones.
Lee Hankins
macOS Tahoe (26.0)
martinij
You are absolutely right. That would be a hassle.
Martin Isak Jansen
www.artec.no
Miha_M
As I said, the use of labels would be a workaround solution. I would also like if we could somehow transfer the marker settings from one to another door or window.
I don't use labels for windows and doors either, but I try to have windows and doors (with their pre-arranged markers) set up in favorites of my template. This way I don't have to go through setting each marker for each new project.
| Archicad 4.5 - 29
