IS THERE A WAY TO MAKE ZONE FILL COLOUR TRANSPARENT?
g r a n t
I'm new to zones and Googling and Forum search has not turned up an answer. I want to use the Zone tool to track Gross Floor Area (area to exterior face of walls). I would like the Zone to be on top of the plan so it is visible to the exterior face of the wall, but still have the floor plan show through. I expected to be able to choose a screen for the colour to allow the zone colour to be semi-transparent i.e. 50% screen. I can pick a screen but it converts the colour to grey...which is likely how that screen was set up. Is there a way to set up the zone colour and then have it semi-transparent? Thank you. Grant
I started learning ArchiCAD at age 50....bear with me,
AC28
MacBook Pro M1 Max.
Sequoia 15.4
It is possible with Graphic overrides.
Set up a GO rule for semi-transparent zones.
Set the fill to 50% (or whatever % you want).
And set the background pen to zero (null pen).
4 REPLIES 4
g r a n t
Hello Barry,
Thank you for taking the time to explain this. I followed your steps and have achieved the desired result. I still need lots of practice but it is working. Thank you.
All the best,
Grant
AC28
MacBook Pro M1 Max.
Sequoia 15.4
Not a problem.
When ever you get stuck, just ask the question here and hopefully someone can help you out.
g r a n t
I am sure I will have many questions. Thanks. G
AC28
MacBook Pro M1 Max.
Sequoia 15.4
