Import Publishing set to a new project...
Llian
How do I import publishing set from existing to the new project?
The new project doesn't have the set…
Thanks
Lilian Seow
LEED AP | cSBA
Interior-Architecture and BIM Management
AC20 USA | 27- macOS 10.14.6| 4 GHz Intel Core i7| 32 GB RAM | Archicad-user since 1994!
4 REPLIES 4
Eduardo Rolon
Try the following:
Eduardo Rolón AIA NCARB
AC26 US/INT -> AC08
Learning: VW, RVT
Teaching & Using: AC, Rhino, ACAD, RVT, SU, AI, PS, InD, TM, C4D, ATL
Llian
thanks Eduardo….it doesn't work.
looking through past posts, look like there is no way to import publishing sets from an existing to the new project…I forgot to use the template I have set up and have already done so much work on it. I think I will open a template an copy and paste. thanks anyways!
Lilian Seow
LEED AP | cSBA
Publisher Set items are based either on Views, or Layouts (which have Drawings based on Views). Views can not be exported-imported between Projects, I suppose because of the complexity associated with the process (you would have to export-import all settings that Views reference). I think this is the reason why Publisher Sets can not be exported-imported between Projects either.
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, Nvidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC26
Loving Archicad since 1995
Eduardo Rolon
Uff, misread the question to mean Layouts, sorry.
AC26 US/INT -> AC08
Learning: VW, RVT
