2023-01-26 05:21 PM
When importing dwg, if GDL is created with the name of a block or dynamic block in the dwg file, can it be imported as a GDL object at the time of import?
Should I make it an API?
This is a question because there are many things that can be done in archicad. ^^
Solved! Go to Solution.
2023-01-27 01:38 AM
Have a look at the translator settings.
This is from 22 (all I have open at the moment), but it will be similar in other versions.
2023-01-27 01:59 AM
THANK YOU SO MUCH ^^
2023-02-01 02:11 PM
How can I link the value of GDL parameter and the value of dwg?
Can I do it with dynamic block?
I don't think it will work, but just in case... ^^
You know archicad is beyond my imagination... ^^
2023-02-02 02:31 AM
Sorry, I don't understand what you are asking.
I don't deal with importing a lot of DWG files, except for site surveys, so I never really deal with converting Autocad blocks to GDL objects.
2023-02-02 02:42 AM
Since the most important thing in GDL is to set parameter values to create various shapes, the question was whether there was a way to set these values in dwg.
In the case of a dynamic block, many aspects are the same as GDL.
(No, it must be close to how to create a family in Revit)
I was curious if it was possible, so I asked.
By the way
https://community.graphisoft.com/t5/Document-Visualize-forum/The-dimension-input-becomes-strange-I-m...
Can you give me an answer on this?
I wonder if it's just me.
2023-02-02 02:50 AM
As I said, I am not familiar with converting blocks to GDL objects, so I have no idea how the block settings translate to GDL parameters.
I did see you other post (I read all posts), but I don't have an answer for you.
If I think of anything, I will answer that post.
2023-02-02 03:50 AM - last edited on 2023-02-02 07:10 AM by Barry Kelly
예! 감사합니다.
yes! thank you
2023-02-02 04:28 AM
Don't forget to translate your posts please.
2023-02-02 07:02 AM
This seems like I did ctrl+c ctrl+v for Korean.
Looking forward to your understanding... ^^
(It's a Korean expression, but I don't know if it's the right translation.)
