Modules and ceiling height
Hello, I would like to create modules with walls who automatically make junction with the ceiling of the floor where they are. If I have multiples instances of the same module on different floors with different ceiling heights, I want the wall height to adjust by itself. Is it possible?
Tank you
1 REPLY 1
Guru
Do your ceilings all have the same offset from the floor above?
Use a multistory module. Set your wall top to the story above with the desired offset, then when you place your module, set it to adjust story height based on host.
Ling.
