Read more
Object text not resizing with scale change
kylevfa
I am using a Basic Electrical Item which has a text parameter baked into the object. Within the objects settings I have set a specific font size however, when I scale any drawings which this object/label appears on, the text "C/U" does not scale accordingly (as seen below). Is this a glitch?
1 REPLY 1
It likely needs some added code to the 2d gdl script, or master script to resize with your global scale
