Openings - Plan view symbol for an slab opening that is Overhead
Aaron Bourgoin
While the manual suggests that i's possible to show an overhead slab opening in a plan view, I haven't been able to find the settings to make this work. Help!
Think Like a Spec Writer
AC4.55 through 28 / USA AC27-6010 USA
Rhino 8 Mac
MacOS 15.2
You have to set your slab to show one (or more) storey/s down.
Then you will see the opening too.
Unfortunately you can't see the opening, if you can't see the slab.
1 REPLY 1
