Place External Drawing Locking Up
In Archicad 18, I am using the "Place External Drawing" to try to place another Archicad 18 drawing into the current one I'm working with. It starts the "update" process, then freezes (locks up). This has happened in several Archicad drawings. I never had this problem with Archicad 9, 11 or 14.
4 REPLIES 4
NCornia
qwsoftdraw,
It sounds like a known issue as described here:
I hope this helps.
Best regards,
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
Amazingly, that worked. Thanks a million. Never would have found that.
David Bearss
Don't use external drawings much but was having same problem. It worked!
Thanks!
David Bearss
Archicad 18/Windows 11
Alienware 17 R5
i7 2.4 GHz / 16 GB ram
I'm glad I found this topic....I was just about to ask the same question.
Thank you.....it has saved me the embarrassment of opening a new topic only to have 20 (nice) people pointing me to this topic...!!
