Got a minute? We appreciate your feedback:
Graphisoft Learn survey
Problem with elevation
ZoreX
Hello guys, im facing a problem, as you can see my elevation is half visible half not... I wanted to save as DWG and ofc when i save vectorial elevation in dwg is blank, so i want to do it black and white with lines... Do you know maybe wahts the problem.
Miha_M
Zdravo!
Several possible reasons.
Layer visibility or layer combination settings?
Elevation marker set to limited depth or limited elevation?
Menu > View > Elements in 3D View > Filter and Cut Element setting set to limited floor plan range?
Renovation filter settings?
| Archicad 4.55 - 26
Anarchiteckt
Hello Zorex
Maybe you have object like a slab or a morph on a hidden layer wo "cut" your model.
You have to change the intersection group of this hidden layer to display your model in a correct way.
Here  you will find another topic who explain the principles.
Gwenael Tripodi, Architect | BIM Manager
AC 8.1-26
MacOS Big Sur | 3,8 GHz i7 8Core | 24GB | AMD 5500 XT
