Read more
Re-numbering windows problem
I seem to be having a problem getting the id manager to rename doors & windows in AC19, I have selected them in the order I want them to numbered selected the unique id for each element etec etc, but they re-number randomly!
I have re-done it over & over, but cannot get it to work. Help!!!!!
5 REPLIES 5
Fixed it! it was the element id in the selected criteria box needs to be removed!
DGSketcher
Legend
I struggled with this a few months back and thought the select order was permanently broken.
Thanks for the fix
OK, so for anyone interested in this, here is a bit more detailed description:
The situation: there are elements that were placed in a certain order and so their Element IDs were assigned accordingly. You want to change these element IDs by selecting the elements one by one and you want the IDs to be assigned to them in the order they were selected.
For this to work make sure that there is no criteria in the Selected Criteria field. If there are no criteria the new IDs will be assigned in the order the elements were selected.
However, if there are any criteria, the IDs will be assigned in the order resulting from the Criteria.
Thus if you have "Element ID" as criteria, then ARCHICAD will take the Element IDs of all selected elements, arrange them in a list internally, and then assign the increasing IDs based on that list. In our example, the originally assigned IDs were increasing from LEFT to RIGHT, so that is the order in which the Element ID criteria will put them and the new IDs will be assigned to them in that order. Thus the Element ID criterion defines the order in which the new IDs are assigned and not the order the elements were selected. This is why you need the Selected Criteria field to be empty so the selection order will define the order in which new IDs are assigned.
roderick_sarco
Hi Lazlo... thanks for clearing that up but we have tried this recently on an couple of project, I am sure we have nothing selected in the criteria field, and still the new numbering is done with an order that is different than the one in the order of how we selected the items.
I know I once got this to work, but I think this was on a project back in AC17 (maybe) and then on more recent projects it hasn't worked for me !
Roderick Anderson
Design Director
SARCO Architects Costa Rica
www.sarcoarchitects.com
Can you do a short video recording of exactly what you do and put it on Dropbox or some similar place so we can hopefully figure out what the cause of this is?
This is working fine for me the way I described it above.
