Renovation style override pen thickness
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2019-12-19
05:07 PM
‎2023-05-26
02:11 AM
Gordana Radonic
‎2019-12-19
05:07 PM
DNguyen
ArchiCAD 18- 25
(expert in AutoCAD, novice in ArchiCAD)
ArchiCAD 18- 25
Labels:
- Labels:
Renovation Filter
5 REPLIES 5
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-12-19 05:58 PM
‎2019-12-19
05:58 PM
Hi dhnguyen,
Check menu View > On-Screen Options > True Line Weight and see the real line weight of your pens.
There is also an option for bold cut lines. I you don´t want, uncheck it.
Hope that helps.
Hope that helps.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-12-19 07:47 PM
‎2019-12-19
07:47 PM
Thanks for your response. I had it set to "true line weight".
I noticed that if i changed the original color of the 2D line into the same yellow color that I selected for the renovation style overwrite, then the lines will show up with the same thickness as the 3D wall lines... But then that defeats the purpose of not being able to use the default "Existing Plan" Renovation Filter Option.
All of my lines will have the same thickness under the existing plan.
DNguyen
ArchiCAD 18- 25
ArchiCAD 18- 25
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-12-20 11:08 AM
‎2019-12-20
11:08 AM
I noticed that if i changed the original color of the 2D line into the same yellow color that I selected for the renovation style overwrite, then the lines will show up with the same thickness as the 3D wall linesthis is happening in a Layout view, right?
Check the renovation rules for similar yellow colors...
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-12-20 02:43 PM
‎2019-12-20
02:43 PM
dhnguyen:
AC18, an older version, does not have the option to Override Pen Color Only, which is available in AC23. Somewhere between these two versions this option was added.
David
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-12-20 09:19 PM
‎2019-12-20
09:19 PM
I see, thank you, my limitations.
DNguyen
ArchiCAD 18- 25
ArchiCAD 18- 25
