Restore Curtain Wall Glazing.
Gisele
Attached is a screenshot of a curtain wall with "deleted" glazing.
The top part has no glass. How can I restore the glass?
I need to show glass in my rendered view.
AC 26 - 5002 USA FULL
Win11 Pro 22H2 - 13th Gen Intel(R) Core(TM) i9-13900KF 3.00 GHz - 64 GB - 64-bit operating system, x64-based processor
in the 3D window -set the cw in edit mode, select the panel tool and pick the panel type you want to insert. you should be able to replace it that way.
Think Like a Spec Writer
AC4.55 through 27 / USA AC27-4060 USA
Rhino 8 Mac
MacOS 14.2.1
1 REPLY 1
Rhino 8 Mac
MacOS 14.2.1
