Roof edge/ fascia line thickness
Polar Bear
Why are my roof front/edge/ fascia line thickness not showing the same thickness as the rest?
Thanks
Archicad 25 - 5010
Macbook pro 13" /Big sur 11.4 + External 4K 27"
Lee Hankins
Is it formed from a Complex Profile? You will need to set the outline pen of the full used to generate the complex profile to the same pen as the roof you want to match or override it in settings.
Lee Hankins
ArchiCAD 4.5 - Archicad 28 Apple Silicon 27.3 | 28 Apple Silicon
macOS Sequoia (15.1.1)
1 REPLY 1
Lee Hankins
Lee Hankins
