Read more
Scaled Text created by Label Tool
Hi all,
I have copied the following text directly from ArchiCAD help:
Text Blocks (created with the Label and Text tools), dashed and symbol line types, and vectorial and symbol fill types can be defined as either fixed or scaled. You can set this characteristic for each line type or fill pattern in the Line Types and Fill Types dialog boxes (Options > Element Attributes menu).
Can someone kindly tell me where the scaled or fixed buttons are for the label tool. They are cleary visible for the text tool.!!!!!!
Thanks
David Larrew
AFAIK - The Label Tool text does not have the "fixed or scaled" option like the Text Tool.
This has been previously posted on the AC Wish List.
It looks like you found another mis-documented feature that was never implemented.
David Larrew, AIA, GDLA, GSRC
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
GS has been notified, the Help file will be corrected.
