Section Text Overrides size
Eduardo Rolon
Using Built In Section Marker cannot edit Text Overrides font size and it is in MM instead of points.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
David Maudlin
It looks like a bug. The font size becomes active when the Working Units are set to to some form of Metric, but is inactive when using Imperial Units.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Odd it is working for me (version 22).
Yes it is in mm but I don't use points anyway.
If you don't override any of the lines, can you edit in the main 'Marker Text Style' section - this all becomes un-editable when a line override is chosen
David Maudlin
David
Daniel Kovacs
David is right, this is a bug (fix #254885). I let the developers know, and they will fix it as soon as possible.
Regards,
Daniel Alexander Kovacs
GRAPHISOFT
