Stair line weight
2raarchitecture
Those very thick lines should be narrow lines and I have tried everything. Will you please, share some insight? Thank you! Images are attached. I have the same trouble on handrails.
2RA Building Workshop
www.2rabldgworkshop.com
11th Gen Intel(R) Core(TM) i7-11800H @ 2.30GHz. 16.0 GB. NVIDIA GeForce RTX 3060 Laptop GPU.
ArchiCAD 25. 5002 USA Full
David Maudlin
2raarchitecture:
For the 3D pen settings, look at the Finish > Tread and Flight panels. The panel in your screen shot is for the plan display.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
Thank you kindly for your reply. The solution was to change the model view options for both railings and stairs to full instead of simplified. Please, see attached.
