Storey Level Markers
S A Harrison
Hi, is there anyone who can help with storey level markers overlapping in section/elevation when there is only 300mm difference between the 2 storeys that are to be labelled? Is there a way to manipulate the line and label?
Sean Harrison AC 17, Windows 7
Sean Harrison
AC18, Windows 10
2 REPLIES 2
It would depend on the storey marker that you are using.
But I am guessing you won't have much control if you are using a default Archicad one.
You can change the text size and probably swap the positions of the storey name and height text - but that probably won't help much.
You will find the options in the 'Storey Levels' section in the 'Elevation Settings' dialogue.
Also in your storey settings you can turn of the markers for individual floors so you could turn off your ceiling height one.
Leaving just the actual floor levels on.
S A Harrison
Thanks Barry. I am using the default AUS 17 storey markers. And, as you suggested altering text size and/or position isn't quite doing it for me. I'm thinking I will just turn off the FCL storey level label and draw a custom one over the sections & elevations.
Sean Harrison
Sean Harrison
AC18, Windows 10
