The reason most of the Tags and Categories parameters are not available is that before placement the Label displays default settings. At that point the Label doesn't know what element it is assigned to so it cannot show you the Tags and Categories parameters (including its custom IFC properties) of the element.
Place the Label with the Associative geometry method, then select it and you will have all those parameters available.
