Total surface by apartment on plans
I'm modelling a building with multiple appartements and I would like to add in a plan the sum of all surfaces:
Appartement A - 130 m2
Appartement B - 127 m2
etc...
Is there an object or something that can add the surfaces and present them on a plan?
Thanks kindly
15 REPLIES 15
I was testing in on Archicad 22
The image you showed with the missing library was definitely not 22.
Has to be 19 or before because of the coloured icons.
The 22 object will not work in older versions.
Sorry, but it is archicad 22 on a mac.
Really?
Because in Windows since version 20 there has been no colour in the icons at all and I believe it is the same on a MAC.
Unless you are using a 'Start' or 'Solo' version of Archicad - I am not sure about those.
David Maudlin
Barry:
The Missing Library Parts folder, in the Library Manager and Library Loading Report, is red on the Mac version, in versions AC22 and AC23 (I just checked).
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
I wasn't referring to the actual missing library parts dialogue (that is red in Windows as well).
I was looking at the icons in the tool bars and menus.
I don't have a MAC but I am pretty sure that the MAC icons are the same as the Windows ones - for the FULL Archicad version anyway.
