Trouble Publishing my master layout
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2011-04-19
04:43 AM
2023-05-26
12:06 AM
Gordana Radonic
2011-04-19
04:43 AM
I'm having trouble publishing my master format so that I may print them. I can't seem to drag the two master layouts in the organizer to the publisher set. Is there something that I'm needing to do to be able to drag the two master layouts to the publisher sets? I'm needing to print my model with various views onto D sized paper. Any help would be greatly appreciated.
Thanks
Labels:
- Labels:
Publishing
Views
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-04-19 05:12 AM
2011-04-19
05:12 AM
You don't drag your Masters to the Publisher. Masters are assigned to Layouts. The Layouts can then be published.
The procedure is ...
Save views to View Map (with Layer Combinations, Model View Options etc set as required)
Go to layout
Assign Master (drawing title block) to layout
Place Views (drag and drop from view map) onto layout
Print / plot / publish
Go to layout
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-04-19 06:14 AM
2011-04-19
06:14 AM
Ok I'm still not understanding how to assign the Master to the layout where I can publish it. I have the Master in the Layout book of the Organizer. How am I able to publish it from there?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-04-19 06:24 PM
2011-04-19
06:24 PM
If you'd like to just print/plot a blank version of your title block (master layout) then simply create a new layout using the desired master, drag that layout from the layouts column of the organizer to the publishing column of the organizer and publish.
