a month ago - last edited 3 weeks ago by Laszlo Nagy
Hi there. How can I change a double brick veneer wall to a black solid veneer wall in my floor plan?
Solved! Go to Solution.
a month ago
The first part of this video should give you a generic method of how to create an external solid brick wall composite.
https://www.youtube.com/watch?v=WCGJMHn2BwY
Hope this helps ?
a month ago - last edited a month ago
This should all be in the default template.
a month ago
You mean fill in the cavity?
Graphic Overrides will help.
You should have a rule that turns all cut fills solid & black.
a month ago
Hope this helps ?
a month ago
I mean the double bricks should have shown in solid black.
a month ago
Barry, the graphic overrides not working for this case. could you please provide more assistance?
a month ago
Thanks Barry, how to show the cavity as a white colour?
a month ago
Ignore above. Problem resolved. Please answer my question about window patterns in another post. Thank you so much
a month ago
For that, I would just use an alternative pen set rather than Graphic Overrides.
Just have a pen set that turns the wall fill pen colours to black.
Of course this will affect anything else that uses those pen colours - so may not be the solution you are looking for.
But if the entire plan is to be black and white, that should not be a problem.
a month ago
BarrySorry for bothering you again. I set my floor plan to all black solid fills, but when I switch to another view and come back to the floor plan, it resets to the previous setting.
