What determines if a building material shows an outline or not in elevation??
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2023-02-02 06:26 PM
AC26
https://www.zendsign.fr/
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-02-03 11:08 AM
Hi Barry, its definitely a Building Materials issue. I spend a lot of time checking everything and it all came down to a select few Building Materials which seemed to be bugged somehow. I rebuilt the Materials from scratch and they work fine now. Its possible that they were Building Materials from someone else's template file that I imported , possibly from a different region version (US). I suspect this might have been the problem.
In the past I have built my project template files off of other peoples template files as a starting point. I think this can cause a lot of issues and I wont be doing it again.
AC26
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-02-02 01:05 AM
In elevations beams and roofs ae not showing any outline, why would this be??
I have set to elevations settings set to Uniform pen, color fill, non shaded
How do I control the outlines for beams and roof objects?
I have be trying for the last half an hour.
Thanks
AC26
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-02-02 02:11 AM
Check your View Style?
View => 3D View Options => 3D Styles => Contours => Show Contours
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-02-02 05:00 PM
thanks for the reply. It seems to happening on the building materials level.
Some building materials have an outline , some do not. And yet I cannot see how this determined.
AC26
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-02-02 07:23 PM
As far as I know it’s not a BM outline but an element skin outline which you can change according to the element’s floor plan and section settings via uncut line type & pen color.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-02-02 07:48 PM
Thanks.
It strange because the same element changes just on changing the Bmat to something else. And even when I edit the first BMat that wont show outlines so that it has the same Fill and Surface as a BMat that will show outlines, the first BMat still wont show outlines for the element. And changing the outline settings for the element does nothing.
Its as if the Bmat is bugged.and overrides any element outline pen settings.
AC26
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-02-02 08:27 PM
Have you checked the elevation settings? It has its own settings for uncut line types and pens,
all I said is for floor plan view.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-02-02 09:11 PM
I have checked elevation settings, view settings, element settings, fills, materials, surfaces.
I dont know what setting affects element outlines in elevations except the element outline pen, and this is not changing anything in this particular case; Choosing certain building materials turns off an elements outlines in elevation, and I cannot see why this is.
AC26
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-02-02 09:14 PM
Thanks, but are 3D view styles applicable to Elevations?
I have so far found that the issue is specific to certain Building materials. regardless of all other settings.
AC26
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-02-02 09:21 PM
If you can attach a s screenshot to help us understand your case.
