White fills printing black in Plotmaker
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2003-12-31
11:03 PM
2025-02-10
04:49 PM
Aruzhan Ilaikova
AC26 (since AC6.0), Win10
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-01-02 06:57 PM
Are you printing or plotting to the DesignJet? I assume that you are plotting because I have never seen a printer make the mistake of printing white as black. In any case I suspect the problem is somehow due to settings of the DesignJet itself. Was it working properly with earlier versions of PlotMaker?
PS. Please provide more specifics about your hardware/software. (ie. Which DesignJet? Plotting directly, over ethernet, or using a server/spooler?) It makes it much easier to respond meaningfully.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-01-02 07:12 PM
Definitely PRINTING, directly. HPDJ430, using standard HP driver, and Windows spooling. I recall having had problems like this with earlier versions of Plotmaker, and I think I've just used the "Empty Fill" route to get around this.
I don't know what setting in the HP DJ driver could be responsible for this. I've got it set to "Color as grayscale" rather than "color to black." Don't see any other setting that might be responsible. Also, don't have problems with other programs using white fills. So, I'm stumped.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-01-02 08:38 PM
my logo has a white text over solid black areas. I plott to an HP 650c and it works fine. If you want, I can send you a copy to see if it prints ok on your end. If it does, you check out my pen settings and make similar setting changes to your pen "91".
Email me with an address if your interested.
Good luck,
Architects Design Forum, Ltd.
Robert Mariani
MARIANI design studio, PLLC
Architecture / Architectural Photography
www.robertmariani.com
Mac OSX 13.1
AC 24 / 25 / 26
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-01-02 08:46 PM
Happens to me too. Inkjet printing. Plotting seems to not mind (ie. it is DESIGNED to PLOT)...
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-01-02 10:44 PM
Previously, I had avoided plotting because some of the formatting (underlines, etc.) were not showing up correctly in OLE documents when plotting but were correct with printing. However, this last test plot looked pretty good with everything! So I guess this is the answer: PLOT.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-01-03 12:50 AM
Richard wrote:Hi Richard,
I 'print' to an HP 500 and have no problems. I did have exactly the same problem you're having when I was learning to use AC with 6.5 a few years ago, and can't remember what the issue was (it was me and not the printer). Djordje figured it out then, as I recall. Escribe doesn't seem to search back far enough for me to find his post.
Since you're seeing the fill properly in the preview screen in PM 3.1 - pens-per-drawing and per print and display options correct, I would assume that the problem is in the printer driver itself. Do you have any options set in the printer setup dialogs that might affect colors?
In the HP 500 print setup dialog, there is a tab for CAD that lists an option for "lines and fills color" with an option for "use application colors" or "use only black". (I have "use app colors" selected.)
Also under the Color tab, there are options for "Color", "Grayscale", and "True Black". (I use "grayscale".)
Just punting...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-01-03 01:30 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-01-06 08:08 PM
What do you have set as "Fill Background Color:" in the "Options\Preferences\Miscellaneous"?...
What do you have set as "Fills:" in "Display Options"?...
Have you tried saving to "PDF" and printing the .PDF file?
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-01-07 06:57 AM
David wrote:David, yes, I've checked to make sure that "All colors to Black" is NOT checked.
Did you check to make sure the the "Output Color" in the "Drawing Settings" is not set to "All Colors to Black"?...
Fill Background Color is set to "Use element's color"
Fills are displayed as vectorial in Display options.
PDF's print fine. HP Laser printer prints fine. It's just the HP DesignJet printer that doesn't. (But it works fine as a PLOTTER) This might lead one to believe that it's something in the DJ PRINTER driver that's the culprit, but I'm stymied as to what it could be.
