Window with 2 panels of different material
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2015-03-19
11:01 AM
‎2024-12-30
05:01 PM
Molinda Prey
‎2015-03-19
11:01 AM
Hi
I am trying to create a vertical window, where the lower part is fixed and the upper part is openable.
I need the lower part to be a different material, in this case an opaque glass or panel. But in the window menu I don't find the possibility.
Is there any way to do it? Thank you very much.
4 REPLIES 4
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-03-19 11:48 AM
‎2015-03-19
11:48 AM
If you are on ArchiCAD 18, Vertical Multi-Sash Window can give you the lower part fixed and the upper part openable. However, I don't think you can individualise the glass material. One for the wishlist?
If you add your OS and ArchiCAD version to your signature, you will get more accurate help on this forum.
Cheers.
Cheers.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
bT Square Peg
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-03-19 01:00 PM
‎2015-03-19
01:00 PM
Thank you for your tip. My problem is indeed the material, I have already a window with two panels.
I'd definitively add it to the wishlist.
PS: signature updated😉
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-03-19 01:15 PM
‎2015-03-19
01:15 PM
You should be able to achieve what you want with the Modular Joinery Object. It is available from BIMcomponents for users on SSA.
= v i s t a s p =
bT Square Peg
bT Square Peg
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-03-23 04:23 PM
‎2015-03-23
04:23 PM
You were right, I was using a different window object from another library.
Perfect, Thanks!
Perfect, Thanks!
