Read more
Zone fills are extending over the border line and into door openings?
Vivijanoz
I need some help disabling the way zones extend over the border line and into door openings.
I have disabled every option in Project preferences > Zones, but the thing still does it!?
How do I fix this issue! Please help.
Thank you.
Archicad 25, build 4013
Montenegro
6 REPLIES 6
mija
Edit:  My mistake, just saw you did everything. Is calculated area correct? Did you update the zones after unchecking the settings?
Montenegro
If you check the picture I posted, I did exactly that and it still does it.
Sorry, my mistake, just edited my reply
Montenegro
Hmm yeah It seems the calculated area is wrong, its adding those parts under the door... Should be 2,9m instead its 3.16m. How do I update the zones now that I've unchecked the setting? Thanks
Montenegro
Vivijanoz
Thank you, this was the missing part 😅
