Zones with Renovation Status set to "New" won't show on Schedules
mendezarcediego
I created some Zones and set their Renovations Status to "New" and they won't show on a simple Zone Schedule. I tried to replicate the issue on a New template and everything works fine.
AC26–5002 INT FULL/ MacOS Monterrey 12.6.3 / iMac Pro (2017) / 3,2 GHz 8-Core Intel Xeon W / 32 GB 2666 MHz DDR4 / Radeon Pro Vega 56 8 GB.
mendezarcediego
ANSWER FOUND! It's quite simple. This issue is if your working on the "Project Map" rather than the "View Map" the Schedule will inherit any random Renovation Filter which might be active in my case one that is not showing new elements, just place that empty schedule on the View Map" and save it with the desired Renovation Filter
vistasp
Good you figured it out. It's best to form a habit of working in the View Map instead of Project Map.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC 9-26 INT | Win10 | Ryzen 5700 | 32 GB | RTX 3050 |
