archicad 23 file opened in archicad 26
xdanaem
I opened a file that was created in Archicad 23 in Archicad 26 and when I print or export the letters are unreadable.
It happens with every file I open and try to print unless I create all the text boxes and write it from scratch
Eduardo Rolon
Known Bug in outdated AC.
Make sure you are running the latest version.
Read here:
https://community.graphisoft.com/t5/Modeling/Archicad-26-Update-4004-Preview-Antialising-BUG/m-p/357...
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
xdanaem
  Letters in layout and letters when i print  - is there any chance there is a solution to that ? it will take me ages to rewrite everything
Eduardo Rolon
Read here:
AC27 US/INT -> AC08
another Moderator
