dimensions and so forth
Llian
so i created a terrain with the mesh...but here are my problems...
1. level dimensions are showing as 0.00 for all my contour points. i've set z height to 1'-0 and sections shows contours slope of 1'-0".
2. i've used sea level and the mesh plane is set to 122.76' from sea level so the section is fairly thick. how do i adjust the view so the 3d is now showing the thick earth?
archicad 13...student version
Lilian Seow
LEED AP | cSBA | CAPM | PMP
Interior-Architecture and BIM Management
AC28 USA | Windows 10 Enterprise i5 3.10GHz | Archicad-user since 1994!
Make sure you use the "Gravity to mesh" button when placing your spot levels.
I use the gravity button in the co-ordinates palette - but it depends on your work environment settings as to where you might have it.
The mesh tool has 3 options - surface only (they call it superficies), surface with skirt or solid body.
You can change to any of these at any time in the mesh tool settings.
Llian
thanks....so for answer [1]..do i need to redo the mesh ?
Lilian Seow
No you can just select the mesh and change the option in the propeties dialogue.
