dimensions don't show correctly
all of a sudden, dimensions only show on one end, instead of the middle... I don't know where this setting is...or why it started showing this...
CAN ANYONE TELL ME WHERE THIS SETTINGN IS SO I CAN GET MY DIMENSIONS BACK IN THE MIDDLE?
THANK YOU, I FIGURED IT OUT...up at the top in the info box, choose the first set of indicators...
1 REPLY 1
Eduardo Rolon
Looks like you changed the "Dimension Text Placement"
• Select all Dims
• Use CMD+T to open the Settings
• Go to "Dim Details"
• Change to Centered or Classic
No need to shout.
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
