Read more
publish to DWG with no fills?
I have two publish sets.
One for PDF publishing and another one to DWG.
For the PDF set I want to generate drawings with all fills (walls, slabs, etc.) For the DWG I want to publish the same PDF drawings but without the fills, so that I don't have hatches in autocad.
Is it easily doable?
Another workaraound that I may be happy with is to generate DWG in a way that I have no block references. Just ACAD entities.
The issues was raised when I generated DWG to deliver to the other contractors, who don't want fills in the walls, slabs, stc...
Many thanks for all inputs
8 REPLIES 8
You should save separate Views for PDF and for DWG.
The main difference will be Model View Options settings. For DWGs, you can check the Show Cut/Cover/Drafting Fill Contours Only checkboxes in that Dialog. You can also use the Fill Background field's Transparent option.
Thomas Holm
A wish - since you need these views for DWG export only, they should be translator settings - strip fills (drawing/cover/cut), hairlines only, etc etc.
laszlo: many thanks for the tip. the down side to it is that I would need to update both pdf and dwg views in case something changes (e.g., layer add)
thomas: that was where I first look - in the translator settings - and found nothing. a wish indeed it is!
Erika Epstein
Thomas,
Can you make this a wish?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Well, in case of Layers: if you save a Layer Combination with the View, then later the View refers to the Layer Combination. So in case a Layer is added, you can just modify/edit the Layer Combination and the result will be correct. This is why a View should not contain a custom layer combination in it, instead always a named and saved Layer Combination.
Thomas Holm
Erika wrote:
Thomas,
Done, along with a couple of others that I've been nagging about.
Hi
in publish organizer window I have just PDF option to publish. How can i add DWG format also?
Sorry
Problem solved
