"Uniform Surface" option not working in Elevation in AC24 b4007 INT
Can anyone else confirm this?
If I select the "Uniform Surface" option in the "Fill Cut Surfaces With" field in the Elevation Settings Dialog, it is not applied (based on the setting, all cut surfaces should now be displayed with an orange color in the below image).
It looks to me that the result I get is the same as with the "Own Surface Colors (Non-Shaded)" option.
It does not work even if I start a project by using "New & Reset".
In AC23, it works correctly.
David Maudlin
Laszlo:
Yes, it is a bug as noted in this thread: FILL CUT SURFACES WITH: UNIFORM SURFACE.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thanks, I see GS already knows about it and will fix it.
