2023-01-27 08:19 PM
What would be the best place to find out what a button does? Example-the plan and pin in the renovation toolbar box. I've searched everywhere within the program, and within the install package and in the help-forums. Is there an overall list of all the icons and what they are/or do? It would function the same way the glossary functions on school-age instruction books. Thank you : )
Solved! Go to Solution.
2023-01-27 08:48 PM
Under the Help menu, select Show Help Tags, this will show information about those buttons when you hover the cursor over them.
David
2023-01-28
04:14 AM
2023-02-02
07:54 PM
Hi, did you find this in your search ?
[link modified by moderator]
2023-01-30 04:59 PM
The link at the end describes the specific button tool in question, but does not add a graphic - so I was not sure it referred to it. Also, the link posted at the end of the page, seems to be missing.
2023-02-02 07:49 PM
Help Center was the earlier place for Archicad Reference Guides. With the introduction of GS Community, its functionality was replaced. You should use the Online Archicad Help:
https://help.graphisoft.com/AC/26/INT/index.htm
I have modified the above link to point to the correct online Archicad Help page.
