tool buttons
lm803
What would be the best place to find out what a button does? Example-the plan and pin in the renovation toolbar box.  I've searched everywhere within the program, and within the install package and in the help-forums.  Is there an overall list of all the icons and what they are/or do?  It would function the same way the glossary functions on school-age instruction books. Thank you : )
David Maudlin
lm803:
Under the Help menu, select Show Help Tags, this will show information about those buttons when you hover the cursor over them.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
4 REPLIES 4
David Maudlin
lm803:
mthd
Hi, did you find this in your search ?
https://help.graphisoft.com/AC/26/INT/index.htm#t=_AC26_Help%2F050_ViewsVB%2F050_ViewsVB-123.htm%23X...
[link modified by moderator]
AC8.1 - AC29 ARM AUS + CI Tools
24C GPU 7.8TF 32GB RAM OS Sequoia.
Certificate IV Architectural & Building
Technology, (Estimation & Administration).
The link at the end describes the specific button tool in question, but does not add a graphic - so I was not sure it referred to it.  Also, the link posted at the end of the page, seems to be missing.
Help Center was the earlier place for Archicad Reference Guides. With the introduction of GS Community, its functionality was replaced. You should use the Online Archicad Help:
I have modified the above link to point to the correct online Archicad Help page.
