turning off the "blending of elements" feature in section?
Gus
I have been trying to model all the framing of an addition I'm doing so that I can see the floor framing etc in section. However, when I do this using the beam tool to make each member a beam of the proper size (joists 1 1/2 by 10) sill (1 1/2 by 5 1/2) etc. they blend together in section so you cant see how they are stacked. In other words there is no line between them if they are touching. Archicad gets rid of the line that would normally be between the lumber in a detail drawing. Is there any way to turn this blending together of elements off?
www.michaelgustavson.com Architect NY WI IL
Madison WI
Archicad21 MEP EcoDesSTAR Win10-64-bit
EliteBook8570W Corei7-3630QM@2.40GHz
QuadroK2000m RAM32 (2)250GBSSDs
4 Monitors Internet:4Up60Down
Srinivas
You have to change the "CUT Fill" of the Stacked beams so that they have a different fill to get the line between them.
ArchiCAD Services
ArchiCAD since v9 to latest
iMac, Windows 10
Gus
Got it, so easy. Thank you.
Madison WI
