view orientation vs. model rotation
Dave Brach
I usually orient the building so that north is up on the screen, but sometimes to fit the building on the layout I want north to be facing left on the screen.  Is there a difference between changing the view orientation to 90° vs. selecting the entire model and rotating it 90°?
Dave Brach/architect
AC26 MBP OS Ventura
AMD Radeon Pro 5300M 4 GB
Intel UHD Graphics 630 1536 MB
ryejuan
It is better to use view orientation than rotating the model to prevent unnecessary adjustments with your textures, fills etc. basically you'll just save a new view with the rotated view orientation then re-link it back to your layout. 😁
In the end what is your Objective?
ArchiCAD 9 onwards
DGSketcher
Legend
I try to avoid rotated views in my View Map, better to set up an Ortho view that suits your presentation. I seem to have trouble in rotated views with elements rotating unexpectedly or not rotating when needed. For output I do rotate the drawings on the Layout to fit the sheet where necessary, for PDF or Paper this isn't a big issue, but more of a thing on BIMx.
