windows dims in 32nd" but my prefs set to ⅛"?
heathldesign
I had this issue way back with the stair tool where i had set my preferences for dimensions to ⅛" but the stairs were in 1/32" and was told to go into the setting and description dialogue to change it, but that option is gone in AC24. my windows are now dimensioned in 1/32" while my prefs are still set to ⅛" where do i go to change this?
MAC Studio 2022 M1 Max, 32 GB RAM, 10 cores, AC26 5003 Apple Silicon USA
18 REPLIES 18
you need to modify your Dimension Style setting for doors/windows.
Think Like a Spec Writer
AC4.55 through 27 / USA AC27-4060 USA
Rhino 8 Mac
MacOS 14.2.1
heathldesign
and where do i find that? i don't see it in the project prefs or the object settings.
David Maudlin
Project Preferences > Dimensions.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
heathldesign
nope. i have that set to ⅛"
Can you show a screenshot of where this Stair dimension appears?
heathldesign
it's the windows in this case.
Are you looking at a View saved from the Floor Plan?
Is the View using the Dimension Settings you modified or some other Dimension Settings?
heathldesign
it's a saved view, but it's the same in the project map. it's also a custom dimension preference, but it's the same if i go with a stock dimension setting.
David Maudlin
heathldesign:
In your screen shot (Project Preferences > Dimensions), select the 6th option from the left (Door, Window and Skylight Dimensions) to set the preference for window dimensions shown with a window marker.
