We value your input!
GDL
2D Text Limitation in Opening Tool
Are there any limitations in the 2D Script of the new(23) Opening Tool. I have to create a 2D text, but it's only shown in the Preview, but not in the plan. Anothe Problem is that i want to show this text outside the opening boundaries, but 2 D Elements outside are only visible in Dignosic Mode.
Thank you
AFAIK - the only way is to do it via label.
(same for skylite objects...where the only 2d script elements are hotspots/hotlines and all 2d stuff can be added via marker/label only.)
Piotr
Peter Baksa
Yes, these are limitations:
- no text
- drawings outside the opening are croppped
- no hotspots
Péter Baksa
Software Engineer, Library as a Platform
Graphisoft SE, Budapest
