GDL
Custom-made MVO
HI!
I follow :
https://gdl.graphisoft.com/tips-and-tricks/custom-made-model-view-options-object
And wrote this code :
! set basic variables
_yCurr = 5
_dy = 25 ! generic line spacing
_totalWidth = 600 ! fixed value to match the exisiting panels
_totalHeight = 4* _dy ! calculate the height from line spacing
_stDialogTitle = "My own (GDL 23)"
! set title and height for the custom MVO panel
ui_dialog _stDialogTitle, _totalWidth, _totalHeight
But I still got :
Is there any changes made in ArchiCad 23 so I need more code?
/Tobias
It works just fine.
You just need to start adding some commands to the interface script.
1 REPLY 1
It works just fine.
