Read more
GDL
Is there a function in GDL to find a specific character in a sentence?
LeeJaeYoung
(I am trying to find out if there is a letter "am" in the sentence "I am a boy.")
AC27 on window 11
Miha Nahtigal
STRSTR (string_expression1, string_expression2[, case_insensitivity])
Returns the (integer) position of the first appearance of the second string in the first string. If the first string doesn’t contain the second one,
the function returns 0.
Note: In case string_expression2 is an empty string, the function returns 1.
case_insensitivity:
0 or not set: Case sensitive
1: Case insensitive
BIMquants.comBETA - Quantities and Costs Estimation with Archicad AddOn :: looking for beta testers - DM
Miha Nahtigal
case_insensitivity:
1: Case insensitive
Thank you so much
ns = STRSTR ("I am a Boy", "am")
return 3
AC27 on window 11
