Read more
GDL
Is there a way to make only one line hidden in something created with Tube?
LeeJaeYoung
Like a complex profile, I would like to implement a hidden line by making only one line hidden and preventing other adjacent lines from appearing.
I would appreciate it if you could tell me how to implement other commands.
AC27 on window 11
5 REPLIES 5
You mean one corner of the profile along the path of the tube?
If so it is the status code of the profile co-ordinates.
Oh, sorry.
I was talking about a section line.
Boundary stone, floor finish and cement mortar under the door.
AC27 on window 11
No, you can't control individual lines of a section through a tube.
Is it possible to control anything else?
If so, I would appreciate it if you could let me know. ^^
AC27 on window 11
With a tube you can control visibility of the start and end surfaces and lines and the lines along the extrusion.
I believe there is an variation (TUBE{2}) that can have holes in the profile (rather than a solid profile) as well as control individual surface materials.
But depending on what you are trying to do, maybe you don't want tube at all?
