Got a minute? We appreciate your feedback:
Graphisoft Learn survey
GDL
Length/Size of one of the sub-arrays of a multi-dim array
dushyant
Hi
Is there a way to get the length/size of a sub-array of a multi-dimensional array?
DIM myArray[][]
myArray[1][1] = 500
myArray[1][2] = 510
myArray[2][1] = 600
myArray[2][2] = 610
myArray[2][3] = 620
myArray[3][1] = 700
myArray[3][2] = 710
myArray[3][3] = 720
myArray[3][4] = 730
VARDIM1(myArray[1]) !gives 4, but I need the size of just myArray[1], which is 2
I tried VARDIM2(myArray[1]) also but it doesn't give the required output.
32 REPLIES 32
dushyant wrote:
Barry, so you mean it builds like a matrix of 3x4 cells and assigns 0 to any non-assigned cells?
I think so.
If you created an array in the parameter list it would look like this.
dushyant
Got it Barry, thanks.
Just wondering if we can loop through the values of a dictionary, like we do through an array:
FOR i = 1 TO VARDIM1(myArray) ...
I have not delved into DICTIONARY yet so I have no idea.
You can loop through the array as you have shown but just ignore if the value is zero.
Something like this?
This will just print the values in each dimension but not the zero values.
FOR n = 1 TO VARDIM1(myArray)
	FOR i = 1 TO VARDIM2(myArray)
		IF myArray <> 0 THEN
			PRINT myArray
		ENDIF
	NEXT i
NEXT n
dushyant
Barry, I had tried that but it seems to still scan through the part inside the IF statement (even if the condition is false) and gives an error:
Uninitialized array element at index: [1][3]
(as I didn't set [1][3], but only up to [1][2])
Dominic Wyss
In that case, multi-dim arrays might not be helpful for what I am trying to do. Thanks guys for the help.
Can dictionaries be looped through?
No. Unfortunately not.
and keys can't be reached by variables... I suggested it, but graphisoft refused
AC26 CHE - macOS Ventura M1
Podolsky
Ace
Just to clear the situation. Do not exist any sub-arrays. Exist one-dimensional arrays: myArray[], myArray[1], myArray[2], myArray[3], myArray[4]...
And two-dimensional arrays: myArray[][], myArray[1][1], myArray[1][2], myArray[2][1], myArray[2][2]...
If you refer two-dimensional array in your script as one dimensional - script won't work and will give an error. That means if you have let say 3x4 array: myArray[3][4] you cannot use anywhere in the script myArray[1]
And, by the way, three-dimensional arrays in mathematic called 'matrix' - like movie. It's when you have z to your array. Just imagine - array tables stack on top of each other. Or multipage excel spreadsheet...
This is all I have written in the Master script.
No parameters in the parameter list and nothing in any other script.
The just open the 2D or 3D preview and it will print ... 500, 510, 600, 610, 700, 710, 720, 730
No error messages that I see.
dushyant
Strange, I get this error..
What version of Archicad are you using?
I did this in 22 and just checked in 25 and still no error messages.
