GDL
Scale or Stretch Texture on the Surface
galiaf_velikiy
Hi, guys. Could you please help me achieve the same scale effect as in SketchUp? The Unproportional Scale is also what I need. Thank you.
undefined
6 REPLIES 6
Lingwisyer
Guru
I think you can just use the COOR commands?
 I am already using COOR3.
bms_buildingMatAttribute_1 = 0
r = REQUEST{2} ("Building_Material_info", buildingMatAttribute_1, "gs_bmat_surface", bms_buildingMatAttribute_1)
mulx	A/           3
muly	B/           3
mulz	ZZYZX/           1
body    -1
model solid
resol       36
    pen     penAttribute_2
    set building_material buildingMatAttribute_1, DEFAULT, DEFAULT
    sect_attrs{2} penAttribute_3, lineTypeAttribute_1
vert{2}	           0,            0,            0, 1	!	#1   VertId=0
vert{2}	           0,            3,            0, 1	!	#2   VertId=0
vert{2}	           3,            0,            0, 1	!	#3   VertId=0
vert{2}	           3,            3,            0, 1	!	#4   VertId=0
pen penAttribute_2
edge	   1,    3,    1,    0, 262144			!	#1   EdgeId=0
edge	   4,    2,    1,    0, 262144			!	#2   EdgeId=0
edge	   2,    1,    1,    0, 262144			!	#3   EdgeId=0
edge	   3,    4,    1,    0, 262144			!	#4   EdgeId=0
vect	           0,            0,            1	!	#1
material materialAttribute_1
pgon{3}       4,    1,    2,    6,    0, -3.000758471779, -2.992290207747,            0,            1,            0,            0,            0,            1,            0,            0,            0,            1,	!	#1   PolyId=0
		   1,		   4,		   2,		   3
material bms_buildingMatAttribute_1
coor{3}	   6,    8,
	           0,            0,            0,
	           1,            0,            0,
	           0,            1,            0,
	           0,            0,            1
body	262182
    material 0
    body    -1
COOR{3} can determine the origin of the surface, it direction and the method it is wrapped, but I am not 100% sure if it can stretch the surface.
Does it need to be done in GDL or can you just create a duplicate surface and increase the size of the texture?
it should be a GDL, I need it for the multiple-use case.
MetalFingerz
@galiaf_velikiy ,
It's possible to scale a texture dynamically by having a DEFINE TEXTURE with scaling variables (and then doing a DEFINE MATERIAL with said texture) but I don't know if it's possible to extract the texture name from a REQUESTed material.
If you already know which texture you want, you could hardcode it directly maybe.
runxel
Hero
It's possible, even tho you must need to do some contortions.
file_name = ""
rrr = request{2}("Material_info", old, "gs_mat_texture", file_name, w, h, mask, alpha)
define texture "new" file_name, w*2, h*2, mask, alpha
tex_id = ind(TEXTURE, "new")
str_name_of_mat = ""
rrr = request("Name_of_Material", old, str_name_of_mat)
define material "new_mat" based_on str_name_of_mat,
	parameters gs_mat_texture_ind = tex_id
mat_id = ind(MATERIAL, "new_mat")
material old
brick 1,1,0.1
addx 1.3
material mat_id
brick 1,1,0.1
Don't get hurt.
